[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 86: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 151: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 152: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/user.php on line 329: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Utils.php on line 210: htmlspecialchars(): Charset "utf8-bin" is not supported, assuming UTF-8 [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4130: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3009) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4130: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3009) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4130: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3009) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4130: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3009) DC Toolkit Pro Plus V26 - DesignCAD DC Toolkit FileLinker Forum
Das User Forum für DesignCAD, DC Toolkit und FileLinker Anwender
Ich habe kürzlich das o.g. Toolkit und DesignCad 3D Print V26 per Download erworben. Die 32 Bit-Version funktioniert wie sie soll - Toolkit starten, DesignCAD startet automatisch. Die 64 Bit-Version (auf die es mir ankommt) zeigt folgenden Fehler:
Ich habe schon -zig Varianten durchgespielt, nichts hilft. Toolkit will immer die 32 Bit-Version.
Mein System:
CPU Intel Core i7 4770 @ 3,40 GHz
RAM 16 GB
SSD 512 GB
Hoffentlich kann mir jemand helfen - DANKE im voraus!
DC Toolkit Pro Plus V26:
1.) Wichtig: DesignCAD 3D MAX V26 32-Bit ist nicht installiert (, da sonst immer die 32-Bit-Version bevorzugt wird).
2.) DesignCAD 3D MAX V26 64-Bit deinstallieren/neu installieren.
3.) DesignCAD 3D MAX V26 64-Bit 1x (!) ohne DC Toolkit Pro Plus V26 mit der Option "Als Administrator ausführen" starten danach wieder schließen.
(Könnte sein, dass damit das Problem schon gelöst ist.)
Wie starte ich DesignCAD dauerhaft als Administrator?
a) Rechte Maustaste auf das DesignCAD-Icon.
b) Menüpunkt "Eigenschaften" (ganz unten) auswählen.
c) Kategorie "Kompatibilität" auswählen.
c) Die Option "Programm aus Administrator ausführen" aktivieren.
d) Mit OK bestätigen.
e) DesignCAD 3D MAX V26 1x (!) starten.
f) DesignCAD wieder schließen.
d) Danach sollte DC Toolkit Pro Plus V26 immer funktionieren.
Gegebenenfalls auch beim DC Toolkit Pro Plus V26 Icon:
a) Rechte Maustaste auf das DC Toolkit-Icon.
b) Gleiches w.o.
Hintergrund: Es könnte sein, dass bei dem Rechner die Benutzerrechte eingeschränkt sind und DesignCAD die Registrierungseinträge nicht schreiben kann. Normalerweise werden von DesignCAD die Registrierungseinträge bei der Installation (hier hat man die vollen Admin-Rechte) geschrieben. Durch den oben beschriebenen Weg kann man das aber auch nachträglich erreichen.
sehr ungewöhnlich. Ich würde noch einen Versuch starten.
Versuche mal DC Toolkit FREE V26 - wenn das auch nicht funktioniert, würden
wir gerne mal einen Termin zur Fernwartung machen - wenn das ok wäre.
Zu 99% war ein solches Problem mit unserer Anleitung eigentlich behoben.
Wir müssen uns mal die DesignCAD Registrierung auf den Computer ansehen.
Kann eigentlich nur eine Kleinigkeit sein.
mit einer Fernwartung bin ich einverstanden. Ich werde also DC V26 + Toolkit nochmal ganz frisch in ein gesondertes Verzeichnis installieren - denn aktuell arbeite ich mit DC V25 - und werde auf die Fernwartung warten (Welch herrliches Wortspiel!). Bitte nenne einen Termin.
DcUser hat geschrieben: ↑Montag 30. Juli 2018, 12:59
Hallo Uli,
ich melde mich direkt (via Mail) bei Dir. Freitag war ich nicht im Büro und heute Montag bin ich noch in der Aufarbeitung (ist halt ein Montag).
eine Woche vergangen und nix von Dir gehört. Wann geht's los mit der Fernwartung? DC V26 liegt hier rum und ruht sich aus.
Kleine Ergänzung:
DC selbst funktioniert als 64 Bit-Version sehr gut, nur das Toolkit will nicht mit ihm zusammen arbeiten. Und das brauch' ich ja zum 3D-Druck.
